Foamed in thermistor in Hoover BHBF integrated fridge freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Foamed in thermistor in Hoover BHBF integrated fridge freezer
  • #101442
    FolkyMike
    Does anyone know the position of the temperature control thermistor in Hoover BHHBF 172 integrated fridge freezer? I need to replace this faulty sensor which will involve cutting into foam at rear panel of appliance. Knowing the position of the sensor will make the job a lot easier.
    #484771
    not sure if that sort of info is avaiable but if you post the long number which is the model code and serial someone should be able to check
