foreign object
  • #50166
    wards
    hi all,zanussi zwf1621w,foreign object inside drum,anyone know an easy way to remove?thanks in advance 8)
    #303829
    bazza500
    Re: foreign object
    Really depends where it is.
    Sump hose off or heater out?
    #303830
    wards
    Re: foreign object
    rattling around in between inner and outer drum,nasty sounding and scrapping on the outer drum,locking up if rotated in anti clock wise direction.hth 8)
    #303831
    wards
    Re: foreign object
    bazza took heater out and can see object trapped in between front of inner and outer drum,hth 8)
    #303832
    Re: foreign object
    There was a whole thread on this some years ago. Each engineer has his preferred method.
    From the previous thread I learned that it’s best to poke something flexible (e.g. green plastic coated garden wire) down into the tub gap. Then rotate drum and wire together until item is carried up and drops out under the influence of gravity. Will probably take several attempts. Don’t give up!
    Mike.
    #303833
    boselecta
    Last one I had I had to take the whole drum out!, could not get object (a key) through seal or element ect.
    Turned out it was stuck behind cross piece.
    Customer had to pay for a tub job though.
    #303834
    wards
    Re: foreign object
    guys took off boot and gently levered drum,objects now removed,now any tips how to get the damn boot back on?trying to get the spring back on seems like you need to be an octopus 😡
    #303835
    Re: foreign object
    Oh dear, here we go again! There was a thread on this some years ago…..hang on a minute…..yes… do a search using the word, “AAAAaaarrrrrrggghhh!!!!”
    Mike.
    #303836
    wards
    Re: foreign object
    mike :rolls: “AAAAaaarrrrrrggghhh!!!!” where ❓
    #303837
    Re: foreign object
    Sorry, for some reason, AAAAaaarrrrrrggghhh!!!! doesn’t work!
    Need to use “aargh” or click here.
    Mike.
    #303838
    wards
    Re: foreign object
    all back together again 8) anyone want a washer that is leaking all over the place ❓ free to good home 🙁 🙁
    #303839
    Re: foreign object
    there was a whole thread on these leaking a few……
    ….oh never mind! sounds like you had a great Sunday.
    #303840
    wards
    Re: foreign object
    stuck it outside ready for scapman,brought a bosch logixx8 hope this ones ok 8)
