Re: F&P 051 error code 00101011
Out of Balance activated.
1/ Check machine is reasonably level.
2/ Check Bias spring is attached between drum and casing.
3/ Check suspension rods are connected and allowing drum to sit square.
4/ Out of Balance switch itself. Check lever is free to move, check function of switch, check condition of switch and wiring. If it’s all rusty, you need to replace it.
5/ Possible that the control board is at fault, but that would be unusual.
