Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P 085
- This topic has 7 replies, 1 voice, and was last updated 20 years, 9 months ago by
alexa.
June 30, 2005 at 1:16 am #10424
alexa
Participantpeeved wrote:
Hi Alexa
From reading past forum posts, I think your just the person who could help me.
I have a Fisher Paykel 085 “smart !!!” Drive 5kg washing machine (bless its soul)
I bought it second hand from a dealer, came with 12 month waranty, of course it broke down 14 months after buying it.
It all started when the the water would not flow properly into the machine. I was told that it must be a water valve, so I changed the one that I thought was bad. Plugged everything in and then BANG sparks and smoke came out of the motor control board. Opened it up and found that a fuse had blown, thanks to a cockaroch shorting it.
New reconned motor control board ( AU $200) and then I was stuck with the same problem, after buying another balance sensor, I managed to get the water to enter the machine OK. But the problem is that now the pump will not empty the tub, it works for about 10 seconds, then stops, works 3 seconds then stop and carries on like this for about a minute and then a warning sounds and a number of leds are displayed.
Am I right in reading this same problem in a forum ?
Also I think you have the diagnostic decoding info, could you please send them to me…….
I am at the end of my wits with this machine, and it is getting to be costly.
I need help……June 30, 2005 at 1:18 am #139876alexa
ParticipantRe: F&P 085
Post your email address and I’ll send you the diagnostics
June 30, 2005 at 1:19 am #139877alexa
peeved wrote:
THANK YOU VERY MUCH.
My e mail is as follows: ananda@kooee.com.au or failing that :
ananda_brown@yahoo.es
I can sense a happy ending to all this.
Thanks again.June 30, 2005 at 1:20 am #139878alexa
Run the diagnostics and post back with the fault code
July 1, 2005 at 6:23 am #139879alexa
Thank you again
There is some interesting info on the stuff you sent me, firstly my
machine had water in the tub when I fitted the new motor control.
Next I have done a diagnostic ( level 3 ) and the result I got back is
“11”.????
Should I sit down to read what you are going to tell me ?
Thanks again.July 1, 2005 at 6:25 am #139880alexa
ParticipantIs that fault code 11?
Have emailed you the readoutJuly 1, 2005 at 6:30 am #139881alexa
ParticipantPM to peeved
You appeared to emailed me fault code 11
I sent you the readout for this fault code
Has that helpedJuly 4, 2005 at 12:24 am #139882alexa
OK
I think the problem is solved, I have done 3 loads, and all seems to be working fine. The problem was as the machine said (code 11). Tub needs to be empty before connecting the new motor control.
Thank you very much with your help. You have saved me money and face.
P.S. almost upset that the problem was`nt a bit more challenging !!!! -
