Re: F&P 601 Clothes washer errors with 101011 (Error 43)
Thanks Penguin45. Removed the user IO front panel and control board to expose the switch. Found the switch Open Circuit so I flushed it with CRC 5.56 until it was soaking. Switch now works as new and the missus can get a full spin out of it.
While we have the covers off, what’s the blue “wire” within the clear tube which comes up from the dark depths? Goes into some sort of sensor on the control board. Might be a moisture sensor?
Gr8 job.
