Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P 601 does not fill
- This topic has 5 replies, 3 voices, and was last updated 20 years, 7 months ago by
Lindsay.
September 12, 2005 at 6:31 am #11917
Lindsay
ParticipantHi, I just found your site recently, and it looks like a great resource. I’ve tossed a few old washers before because I couldn’t diagnose them, and they were too old to warrant the cost of a professional. Hopefully with your help I won’t have to toss my F&P – or at least I’ll know what I’m getting into with a repair.
I have a F&P 601 that does not fill. All lights are on & power seems fine. I think (never done it before) the diagnostics are 000 001 00 010. Can anyone help me with this beasty?
thanks,
LindsaySeptember 12, 2005 at 1:11 pm #147166FastAndPro
ParticipantRe: F&P 601 does not fill
Is it filling slowly or filling in bursts before fault codeing have a read in the forms on diags and testing inlet valves
September 14, 2005 at 7:13 am #147167Lindsay
Doesn’t fill at all – absolutely no water flow. I have manually filled it to see what would happen, but still nothing. It wouldn’t wash, spin, or empty. So I poked around inside it to see if there was anything obviously wrong, but I couldn’t see anything. Any ideas welcome!!
September 14, 2005 at 11:31 pm #147168FastAndPro
Is the drum turning if not it may just be the lid switch do a search on Fisher paykel and try to give us a bit more info on the fault
October 11, 2005 at 8:18 am #147169Lindsay
Ok, I’ve got sick of going to the laundromat to do my washing, so I’ve had another go at my machine.
The problem is that the lights light up & it appears to be ready to go, but absolutely nothing happens when I attempt to start a wash cycle. Following instructions from this site, I’ve managed to find out the following though:In diagnostics mode, the light sequence is:
00010000011. hopefully this means something?Also when in diagnostics mode, depressing the wash temp up button fills the machine with hot water. depressing the wash temp down button fills it with cold water. Depressing the regular button empties the machine. I guess this means the valves and pumps work.
any insights into this would be most appreciated. Thanks.
October 11, 2005 at 8:34 pm #147170Penguin45
Should be a rotor position sensor fault, down by the motor. Can be wiring, sensor or electronic board. You’ll need a test meter to test properly, power off when inside.
Penguin45. -
