f&p 608 error code
  • #16865
    sinister_designs
    can someone tell me what is code is for
    00000100101 read from left to right.
    I believe it is something to do with the draining?
    thanks
    #171925
    Re: f&p 608 error code
    Correct – pump block error.
    Check for blockages, pump overheating and cutting out, pressure switch function.
    Pump is permanently live if appliance is plugged in, so pull the plug.
    sinister_designs
    thanks
    had a quick look & spun the fan attached to the pump motor started working again so new pump might be in order now.
