G’day
My F&P has an error code 132 I think – 10000100.
All looks clean.no rust under.
It starts to fill for half a second, then stops, then starts, etc. Then error lights come on.
Any more clues pls?
PS the diagnostic codes FAQ at the top of this forum have the number codes listed as 1+2+4………+64+132 and I think this should be ..+64+128.
this is why my original posting gave error code of 136
Right – unfortunatley, BSPs reply to your original thread is still basically correct. Defo motor problem, wiring – windings, position sensor all suspects.
If I try various parts of the cycle, it goes for a short time, so the motor actually works. The wiring all looks clean and there is no sign of rust or leaks underneath. Where are the sensors that are mentioned in some posts and how do I tell if they are functional or not?
thanks
Mac
The most simple thing to check would be the Out balance Micro switch
This Sits under the Motor Controller On RHS(top control deck)
These give a bit of grief sometimes with this problem
Check switch for corrosive terminals & check bracket that that houses switch
(the little lugs Break)
RPS Sensor is located under washer bowl in the motor area
