F&P 703 the misses is killing me
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P 703 the misses is killing me
  • #27739
    busted100
    the 703 is statring to play up after 10 years or so and after finding this site I thought I would try to go through the error codes.
    held down water temp while hitting the power. No Beeps, so I toggled the the spin buttons till slow and hold were alight any way but the Water Level High and Low were also alight. So after my failure I went to turn it off and all the led’s between Rinse and Spin lite up and would not go out unless I turned it off at the wall.
    HELP ME
    #215411
    Re: F&P 703 the misses is killing me
    Help thyself………
    The recycle feature is on, instead of off, so the machine will repeat any cycle for ever. To turn recycle off:
    Hold wash temp down and then press power. Wait for the two beeps. Press and hold advance, press water level up once, then power off.
    That should do the trick.
    Then tell us what was originally wrong with the machine…………. 😀
    busted100
    tried the above and same results
    Problem, the machine would be very slow to fill if just on cold water (a very slow trickle almost drips) but once washing it was fine until the other day it would get to rinse stop and start to beep with the hot and cold water temp buttons flashed
    #215413
    So, probably a cold water valve problem. This a proportional flow device – the bigger the voltage, the faster the flow. They do play up, so that’s the place to start.
    busted100
    so if I was to hook the coldwater to the hot water inlet and set the temp to hot it should run and fill etc faster? (until I get the new valve anyway)
    thanks, I try that and see how we go
    #215415
    Until you get to rinse – cold water only……….
    busted100
    yeh up to that stage now and it is taking for ever to go through the rinse. Will try and get inlet proportional valve, hopefully this solves the problem.
    May have to top up the rinse cycle by bucket
    #215417
    busted100
    would there be a problem using part no. 426142 (inlet proportional valve – hot water) instead of 426143 (cold) is there really a difference between the parts?
    Thanking you inadvance
    #215418
    Was wondering where you’d got to………
    426143 is the cold water valve. It is a proportional flow device, ie, by controlling the voltage supplied to the valve, the machine can vary the flow of cold water into the machine against the hot.
    426142 is not a proportional valve. It gets hit with 12vDC and is either open or closed. Much less than 12v, it won’t work at all………
    Better buy the right one.
    busted100
    thanks for the quick reply, I had been caught up with work etc and finaly had a chance to pull out the valve (just lazy and the misses does the washing). Will try and source part tommorrow(Monday), seems a common problem with these machines the more I read the site so hopefully they part is in stock.
    Thanks again, will let you know how I go
    #215420
    busted100
    Thanks Penguin45, proportion valve is in and all is fine. Washing as per new, again thanks for the help. 😀 😀
