f&p 708 burnt motor contoller
Home Forums Public Support Forums International Forums Australasian Appliance Forum f&p 708 burnt motor contoller
  • #11417
    grossy
    Had no power to washing machine traced it to the motor controller burnt transistor ! Replaced board and suspect OOB switch. Done 2 more washes and the same thing happened same transistor burnt, attempting to replaced transistor and now run diognostic mode when I found out how.
    Has anyone heard of this and do you know how to run diognostic mode.
    Did display a code once with the beeps : led on short wash and the last 2 led’s on aswell
    Cheers Grossy 🙂
    #145299
    Re: f&p 708 burnt motor contoller
    There should hzve been a checlikst in the box with the board. Usual suspects are inlet valves 65 ohms, drain pump 32 ohms, motor 32 ohms across any 2 terminals, and lidswitch wiring rubbing on cabinet. Check these first.
    #145300
    grossy
    Cheers
    😆 I went straight for the lid wiring and bingo its been arching on the body. plan to still do diognostic if anyone can help, once i replace the transistor and wiring!!!
