f&p 708 squeeks in agiation Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › f&p 708 squeeks in agiation This topic has 3 replies, 2 voices, and was last updated 19 years, 1 month ago by goanna. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts February 19, 2007 at 12:12 am #25167 goannaParticipant While the machine is in the wash cycle as the agitator stops to change direction the 708 give a loud squeal like a loose belt or fried bearing. Please help Goanna 🙁 February 19, 2007 at 12:38 am #204775 Penguin45Participant Re: f&p 708 squeeks in agiation No belts……….. Bearings possible. Bearings do tend to make more of a rumble than a squeak. Loose motor rotor can make some interesting noises if not fully secured. Might be worth pulling paddle and making sure nothing is trapped underneath. Penguin45. February 19, 2007 at 3:37 am #204776 goannaParticipant Re: f&p 708 squeeks in agiation thanks for your reply I hear you in regards to bearings. Could this be as simple as the suspension system needing some lube ? goanna February 19, 2007 at 4:21 am #204777 goannaParticipant Re: f&p 708 squeeks in agiation no lube did not help noise is definitely coming from the bottom of the machine help please Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
