I need some info on how this system operates, I replaced evap that was punctured. evreything works fine except that it wont switch off, if you open the freezer it will beep a few minutes later and wont stop beeping until you press the mode switch, frig and freezer come down to temp ok.
Maybe it has a system reset code ?
Re: F&P Active Smart E372B Fault and diagnostic info ?
Found the problem. bad wiring loom crimped connection in plug socket to fan, this is a factory fault that could affect just more than one unit.
makes controller think that fan is not running when it is.
Just cut it all out and make your own new connection
