F&P Aquasmart Model WL70T60 Diagnostic Mode
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P Aquasmart Model WL70T60 Diagnostic Mode
  • #47409
    Suse10
    Hi, I have a Aquasmart washing machine, which I got free after it had gone under water in a flood. It cleaned up OK and I have disassembled and cleaned the controller, motor and pump.
    It powers up, but will not fill, inlet solenoids are OK, I have operated them via an external 24 VDC supply. Error code is 49, which for other F&P washers, is a failed inlet solenoid.
    How do I get the unit into diagnostic mode, to test values, pump and motor?
    Is there a service manual available for download?
    TIA.
    #293367
    Re: F&P Aquasmart Model WL70T60 Diagnostic Mode
    Diagnostic procedures are outlined in the sticky at the top of the forum.
    49 indicates a cold water valve problem, not specifically a failed valve. 24v valve should show a resistance of 64ohms when metered. Wiring is a common issue. If you have continuity and resistance through the loom to the valve from the Motor Controller end, you probably have a failed board.
