F&P Aw095au Fault 38? (0110010)
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P Aw095au Fault 38? (0110010)
  • #36811
    beer-man
    Hello all,
    Can anyone give me a hand with whats wrong with the machine and also is it an expensive fix? The misses is killing me……Like it was me who broke it
    The error code I think is 38 0110010
    0=light off 1= light on
    Thanks in advance
    B-M
    #252456
    bigsmokepiker
    Re: F&P Aw095au Fault 38? (0110010)
    Fault code 38? (0110010)is fault Code 50 Binary Reading Right to Left
    Fault code 50 is Hot Valve Error Could be Faulty water inlet valve Or (Hot water tap turned On ?)
    On the Other Hand Fault 38( 00100110)is Pressure Sensor error
    Check pressure tube is not kinked or loose other than that pressure sensor which is integrated into Motor controller (Main PCB ) About $200.00Aud
