F+P DD6L31H
  • #24607
    Lawrence
    Hi Guys
    Symptons are leaking in base blowing suppresor .
    To date I have changed
    support arm kit for top hose
    motors for lids -top and bottom (New Style)
    Cleaned the top surround of each tub .
    every time I run it up after repair it works okay ,customer does 3 or 4 loads and hey presto water in base and blown suppressor !
    Any ideas ?
    Lawrence
    #202654
    johnmac11
    Re: F+P DD6L31H
    Hi Lawrence,
    Check the drain hose on the drawer that you changed the support arm on, once arm goes it is not uncommon to get a pin hole due to the hose rubbing.
    Apart from that all you have is either the heater/motor seals or salt chamber seal.
    If I come across one like this I usualy run both drawers with the door off and can spot the leak easily.
    John
