I dont have a service manual specific to this model, if I use this code for the codes I have, I get the answer
(Temp sensors outside of normal range as the problem/fault)
does anyone know if this is in fact correct for this model
Tried the turnoff cure, but didnt work, seems odd that its works ok, temps are ok and aside from the bloody beeping with the door closed. Its runs good
suggestion appreciated
