F&P error 38
  • #43986
    spau
    Hi Guys
    My machine is sporadically letting water in. it starts off filling ok then does short bursts of water, then nothing. Ive done the diagnostic stuff mentioned in the stick in this thread and come up with error “38” , assuming the first LED (which is covered by plastic) doesnt count. otherwise its 76. Its a smartdrive 085 model. Any help greatly appreciated!
    #279314
    Re: F&P error 38
    Sure you’ve got that right? The one covered up is 128 – you need to go from the right to the left.
    38 is to do with water level control – possible that the air hose to the pressure switch is off or holed; or that the pressure switch is faulty.
