Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P fault code long wash
- This topic has 6 replies, 2 voices, and was last updated 19 years, 2 months ago by
king1807.
January 26, 2007 at 2:52 am #24510
king1807
ParticipantI have an older F&P smartdrive GW601 washer and after turned on for short time only the “long wash ” led illuminates and a beep cycles.?
After going through fault diagnosis the short wash and rinse leds are on, code 48 ? does anyone know what this code is please.thanks
January 26, 2007 at 8:35 pm #202345Penguin45
ParticipantRe: F&P fault code long wash
It’s almost certainly a problem with the wiring harness going to the water valves. Check for good contacts, breaks, chaffing, etc. Possible for valves to fail, but unlikely to be both together. Valve coils sjould meter @ 15ohms if you do check.
Penguin45.January 26, 2007 at 9:03 pm #202346king1807
check coils, and 15ohms each, does anyone know the code to manually operate water pump ?.
help much appreciated….thanks.
January 26, 2007 at 9:15 pm #202347Penguin45
Might as well do the valves while you’re at it………
Hold “Wash Temp Down”, then press “Power”. Wait for two beeps.
Use “Regular Cycle” button to turn pump on and off.
Use “Wash Temp Down” to turn the cold valve on and off.
Use “Wash Temp Up” to turn the hot valve on and off.Regards,
Penguin45.January 26, 2007 at 9:34 pm #202348king1807
Hi peguin45
thanks for your help, went into diagnostic mode and unable to get two beeps, when WTD button released the final rinse led on and the low water level on. I was able to get both the water solenoids to operate at this point but no pump.
Could this be the pump?many thanks
January 26, 2007 at 10:09 pm #202349Penguin45
Hmm, interesting – Uk/Euro washers generally won’t fill if the pump is out of circuit as it usually breaks the neutral loop around the machine. Pump should give 26-33 ohms if intact. Check for damaged wiring where the loom turns under the edge of the drum and water damage. You may need to check continuity from the board end to be sure.
Power off – pump is on mains voltage.
January 27, 2007 at 7:03 am #202350king1807
$$$ JACKPOT $$$ GO THE PENGUIN!! Problem found to be open cct coil. Start of coil had break , managed to pull 1/2 turn from coil and resolder.
thanks for the help…
king1807 😀 😀 😀
