Probably Phase 5 Washer IE MODEL MW059 Or GW509 ??
Power off at Console
Press & Hold Temp Up Then POWER Button
Should get 4 Short Beeps
Press Up Temp Botton TIL Cold LED ON For 5-5.5KG Washer
Press Power Button to exit Mode & store
Hi There,
Tried it last night after setting the size and it worked. I will try it again tonight to make sure that it is still in its ‘memory’
Thank you all for your advice.
Andrew
