F&P fridge – rubber mount for evaporator fan gone
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P fridge – rubber mount for evaporator fan gone
  • #59799
    MatthewK
    Hi guys,
    The festive season has KO’d our freezer as it did a couple of times previously. The problem is the evaporator fan up the back – it has a three point rubber suspension mount which hooks onto points on the plastic panel it’s in. A few years ago one of the upper mounts broke and I was able to jerry-rig a fix from elastic which was just fine. However now all three suspension arms are snapped and I have to replace the rubber mount. I have no idea where to find one and my only online success has been finding a complete replacement fan, which I don’t need (and it’s generic rather than a F&P part).
    Feeling pretty frustrated that a small piece of rubber can take out an entire fridge – does anyone have any ideas?
    Thanks for any help.
    Cheers,
    Matthew.
    #339636
    MatthewK
    Re: F&P fridge – rubber mount for evaporator fan gone
    Sorry – I should have mentioned that the model number is E521T and it’s about 9 years old.
    #339637
    johnmac11
    There are a few different versions of the 521T over the years. Can you post up the PN or Product number which you will find on the rating plate and I can then let you know if the mount is available. The PN number is usualy 5 digits long and sometimes has a letter at the end of it.
    John
    #339638
    MatthewK
    Thanks John – a local supplier was very helpful and succeeded in figuring out the part number for me – it’s referred to as a “spring, fan suspended” and it’s in one of the manufacturer information sheets available here:
    http://www.stokesap.com.au/info_sheets_fp_refrigerators.asp
    Thanks again for your kind willingness to help!
