F&P GW500B-U Won’t Spin
  • #35584
    OzTim
    My F&P won’t spin. It gets to the spin cycle, the pump runs for a while, then it just beeps continuously and the 3rd from the left LED lights up, so 00000100. If i then go into diagnostic mode it displays 11010100 when slow and hold are lit.
    For context this happened after i flooded my laundry and bedroom. After this i threw in a couple of loads of just towels on spin mode and it worked fine. When i went to wash them it failed when it came to spin. Their is a fair bit of humidity in the apartment. Finally, the spin light seems to pulse a bit after i push start, before the light changes to third from the left and the beeping starts.
    Thanks, Tim
    #247206
    bigsmokepiker
    Re: F&P GW500B-U Won’t Spin
    Think you might be reading Fault Code wrong way round
    You posted 11010100 (212) No such code
    If 00101011 (Fault Code 43)
    OOB Swicth Fault Numerous Threads on this Problem
