Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P GW600 Smartdrive Motor Control Board
- This topic has 6 replies, 4 voices, and was last updated 19 years, 7 months ago by
Veraphil.
September 3, 2006 at 9:40 am #20523
Veraphil
ParticipantMy neighbour’s Fisher&Paykel GW600 Smartdrive would not show any sign of life after he interrupted a spin cycle that had just started, by lifting the lid.
I had a look for him and found the 6A fuse was blown. I replaced this fuse and turned the power back on – the result was a loud bang and the replacement fuse was blown. I removed the control unit and pulled it apart.
Everything looks OK except for the large power block that has the heatsink.
I removed this unit from the board and found that the bakelite package had partially blown apart.
I have tried Googling the part number of this part (97-0204 IR 9205) but have found no meaningful information. It is pretty obvious that the part is made by International Rectifier, but I know very little else about it.
If I replace this part, is everything else likely to be OK? I think I can get a replacement entire control unit, but if I go this way I would like to be confident that there is no other fault.
Does anyone have any thoughts on this situation?
Regards
Phil J.September 3, 2006 at 10:15 am #187349Penguin45
ParticipantRe: F&P GW600 Smartdrive Motor Control Board
Hi Phil,
This is at least 13 years old, so probably about time something blew! You can chase round the rest of the machine with a test meter to check the other components, I would be worried about the condition of the control board itself. The actual blown component may have been superceded with the passage of time – I do know that phase 1 control boards are no longer available new.Check your email shortly – you in Oz or NZ?
Penguin45.September 3, 2006 at 4:48 pm #187350gegsy
Australia Mr P 😉
September 3, 2006 at 7:25 pm #187351Penguin45
How’d you work that out from a .com addy?
:p45:September 3, 2006 at 8:52 pm #187352gegsy
I will eat Dave if I’m wrong 😆
September 3, 2006 at 9:19 pm #187353Dave_Conway
Over my dead body :happy:
September 3, 2006 at 11:11 pm #187354Penguin45
Right – everybody out………. 😀
:p45:
