F&P GW601-K error code – help!!
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P GW601-K error code – help!!
  • #20075
    sparklz
    I just bought a second-hand Fisher and Paykel GW601-K, and have plugged it in turned it on etc. everything lights up, but the start/pause button won’t work.
    Have trawled forums, getting it to fill/empty in diagnostic mode. The error code comes up as 00100010, can anyone help me out with what I need to do with it? If I need to get a repairman I want to limit his time and effort by already knowing what needs fixing!!
    Thanks.
    #185685
    bigsmokepiker
    Re: F&P GW601-K error code – help!!
    Can you feel the start button clicking on/off
    The other buttons give the same contact as Start/pause Button
    It is very common that this buttons do lose there contact
    If you cant feel a definite clicking then your possibly up for a display module
    Fault code indicates Brake resistor fault
    Circuit that controls braking of motor is faulty
    Could be Motor controller fault Or Display module Fault
    Motor Controller Part #426260p$220.00 Aus
    Display Module Part#426033p $135.0Aus
    #185686
    bigsmokepiker
    #185687
    sparklz
    Thanks for your help, I can feel the start button clicking when I push it. Could this have happened whilst moving the washer in the car? Perhaps from water getting into the circuit?
    #185688
    sparklz
    Do you know if I’m able to differentiate between the two using a multimeter? And if so, how? That way I can just get the part and do it myself. Thanks!
