F&P GW703 pulsing valves
  • #36694
    qualos0
    Hi, I have a fault with a F&P GW703. the inlet valve(s) give very short pulses, and after a short time it just stops and starts beeping. I’ve gone into the diagnostic mode as per the sticky and read a fault of 10000100. This unit has the green control board. Any ideas appreciated.
    Cheers, Tony
    #251976
    bigsmokepiker
    Re: F&P GW703 pulsing valves
    Fault code 132 Single Current trip
    Youwould have to check connections To rotor postion sensor(RPS)
    There are numerous threads relating to this error
    Have to check for corroed terminals Etc
    Would suggest being a machine of this age to check for leaks around the Shaft area Typically water leaks down onto to motor & RPS causing these faults Not good news im afraid
