f&P GW709au Fault code 00000101
Home Forums Public Support Forums International Forums Australasian Appliance Forum f&P GW709au Fault code 00000101
  • #42775
    jimmylad
    Hi, looking for some help please. It fills, washes, pumps out the water but won’t spin…..much. It will spin approx 1/4 turn one way then stop and spin 1/4 turn the other. Have taken all apart and there are no blockages. Fault code 00000101. second from right ie 000001*1 is flashing every 15 seconds or so. Appreciate any help
    #274905
    bigsmokepiker
    Re: f&P GW709au Fault code 00000101
    Fault code 5 Not a fault code
    But from your description Could be the RPS Sensor (numerous threads on this problem )DO A SEARCH.
    Can also be a worn or jammed bowl clutch.
    Access clutch gear by removing agitator & clutch cover or maybe something jammed between bowls.
