F&P GW709au (Won’t Spin)
  • #35158
    I am thinking it is the motor control board. I have replaced the OOB and it still shows a Error Code 43. I have checked all the wiring and had the pump apart and cleaned. It runs fine up until spin then won’t spin up to speed it sounds like it is going to try then in just turns off.
    If you have any other ideas as to what it could be let me know. other than that where can i purchase a Main control board in australia?
    #245351
    kiwireeferman
    Re: F&P GW709au (Won’t Spin)
    Seems a little strange. Suggest you join the wires together at the microswitch. The 709 uses edge connector plugs at the board.
    Remove the plug for the OOB and the lid reed switch. Gently squeeze the plug contacts together and then refit to the board. (If you have a multimeter check that the wiring has continuity from the plug to the microswitch.) If that doesn’t fix it, at least you have eliminated everything apart from the module.
    Never seen a module fail on that code.
