F&P Intuitive eco 6.5kg
  • #36866
    Cylon
    Says on lcd I need service error code 9 ?
    anyone got an answer. mmmm seems to have got over that one all by itself, now I have code 130, water valves & pump pass setup test ok, diverter valve is ok, oobe is ok, lid switch is ok, motor winding are ok. thermistor is ok.
    anymore setup test info is welcome, just leaves rps ?
    #252616
    Re: F&P Intuitive eco 6.5kg
    I dont normally cover F & P but is it the drawer dishwasher ?
    Bryan
    #252617
    Cylon
    Thankfully not, its an iwm10nz washing machine, anyway changed out the rps and now it goes, still not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} satisfied that was the problem. time will tell
    #252618
    bigsmokepiker
    Fault code 130 does relate to RPS Sensor fault
    It May be sensor itself or dirty contacts etc (Sometimes motor Controller can be the culprit )
    Fault code 9 is a sze setting error usually related when a PCb is changed over
