F&P MW051-U Diag procedure and fault codes please.
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P MW051-U Diag procedure and fault codes please.
  • #14302
    thewizardoz
    I’ve got a F&P MW051-U which lights OK when switched on but does not run, i.e. in pressing “Start’ the drum jerks once then nothing more.
    When I go into diag mode I am not certain that I am using the correct procedure for this model – I am using 601 procedure and codes.
    So I would appreciate the correct diag procedure and fault codes please.
    Thanks.
    Mark
    #158931
    Re: F&P MW051-U Diag procedure and fault codes please.
    To enter Diagnostics:
    Power on at socket, off on machine. Press and hold “Wash Temp Down”, then “Power”. Yours is a phase 2 machine, so press “Advance” once. From there, use the spin buttons until “Hold” and “Slow spin” leds are lit. The pattern of lights on the wash progress board will now indicate any fault in binary code, from right to left.
    thewizardoz
    Thanks Penguin45, I’ll give it a try.
