F&P MW053 Faulty Lid Switch again?
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P MW053 Faulty Lid Switch again?
  • #37732
    muzza
    Her indoors is having trouble with the washing machine, giving the similar fault indications as it did back in 2005
    – hold down water temp and press power, release both buttons, no beeps, and I get 00000000 + water level top to bottom 101
    – advance once and I get 00000100 + water level 001, spin toggle inactive.
    At the time it was a suspect lid swith which solved the problem.
    As a fault finding exercise can I short out the lid switch without causing any problems, and see if that solves the issue?
    Cheers, Muzza; on the Gold Coast of OZ
    #256202
    Re: F&P MW053 Faulty Lid Switch again?
    Lid switch is just that, a switch – so you could bridge it for testing purposes only – it is a safety feature after all.
    muzza
    Penguin45 wrote:Lid switch is just that, a switch – so you could bridge it for testing purposes only – it is a safety feature after all.
    Tried that and no change
    To verify I borrowed a multimeter and the lid switch checks out OK. Also put it across the OOB switch and that is also OK.
    So here is what I have done
    For some time the start/pause had been giving trouble so I finally weakened and replaced the switch, and everything worked like a bought one. Last Friday and the machine completed the (thankfully) last wash cycle and shut down kaput! Dead as dodo.
    Completed the test programme as follows
    1. Hold “wash temp down” press power and hold both, all lights come on, then after about 4secs
    2. all top lights are out + water level reads, top to bottom, 101
    3. press advance once
    4. result right to left = 00100000 + water level 001
    5. spin toggle disabled, I get 4 quick beeps from either button
    6. press advance once
    7. all top lights are out + water level reads, top to bottom, 101
    8. spin toggle now enabled, toggle to slow/hold, no change to lights
    9. press advance once
    10. result right to left = 00100000 + water level 001, same as line 4 and 5
    11 press advance once, and you start going around in circles getting the same results as before.
    If I toggle spin button all the way to fast
    12. result 01101000 + water level 101, and spin fast
    amended result, while I was writing this
    13. result 11101000 + water level 101, and spin fast
    Could it be that line 13 spells the death of the washer? or could it be saying a new board is required?
    I have checked the pump and that is not blocked, so I don’t know where to go.
    #256204
    Communications error – motor controller board has gone faulty.
