F&P MW511 does not complete cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum F&P MW511 does not complete cycle
  • #81149
    0t1
    I have a F&P MW511 it goes through the cycle and stops at the second stage of the rinse cycle, then beeps continuously. I have tried the fault code generator by pressing down on the wash temp while turning the power on, I get the 1st and 7th lamps lighting up in orange (left to right). Can you tell what this means. Any help would be much appreciated.
    #415620
    0t1
    Re: F&P MW511 does not complete cycle
    I have found on another forum the fault codes, this code comes up as PRS position rotor sensor fault, I have had a check of the wiring Red , blue and yellow plugs under the bowl, they appear to be corrosion free,however I gave them a squirt of WD40 and some around the RPS unit. I have run the machine again and still get the fault. What’s next? Again any help with this would be much appreciated.
