F&P MW511 lights 3+4+8 on solid and beeping
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P MW511 lights 3+4+8 on solid and beeping
  • #47842
    24mech
    Hi there I got home from work today and loaded the washer I turned it on and it started beeping at me and wouldnt turn off. Can some one please help me I need to know what lights 3 and 4 (the two before short wash green in color) and 8 (spin Red in color) being on and beeping continually means. I tried to carry out the diagnostic procedure you describe but as the machine goes streight into beeping its nadds off I cant do it. Please help I gotta get this thing going again thanks.
    #294773
    Re: F&P MW511 lights 3+4+8 on solid and beeping
    3,4 + 8 R->L suggests 140, which is not any sort of recognised code.
    Pull the plug and leave it for a while; then try the Diagnostics.
    24mech
    Hi there I looked deeper into the fault code I got and worked it out as 0011001 = code 49 I looked around on here and worked that out to be cold water intake circuit, so I took the covers off and had a look at the solinoid it was at 60 ohms I took a look at the pcb and found some corrosion causing cross conections across 4 lines. I cleaned off the corrosion and rebuilt the washer. everything working perfectly again now thanks for your help with this guys. 😀
