Hi all,
Our machine wasn’t emptying, so I had to pull the machine out from the wall and lean it on it’s back last night so I could access the pump – undid the pump, cleaned out the dog fluff that was in there and reassembled.
Now it powers on fine, but
(Symptom One)
Won’t fill correctly – by changing the water temperature (either hotter or colder, doesn’t matter), it will start filling at the normal rate. After about 2 minutes, the machine faults, the lights 10000011 (plus 2 spin lights?) come on and it beeps.
(Symptom Two)
Select spin cycle, machine empties (yay!), however won’t start a spin cycle. Again, after about 2 minutes, the machine faults with the same error code.
Any ideas? I got as much water as possible from the machine before pulling the pump, however some did come out. Beyond that, have I maybe crushed/damaged something by leaning it against the wall?
Cheers,
Mike.
