Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P Smart Drive 701 – Diagnostic tests
- This topic has 3 replies, 2 voices, and was last updated 19 years, 8 months ago by
essandemm.
July 26, 2006 at 11:17 am #19443
essandemm
ParticipantHello anyone! I have a Fisher & Paykel Smart Drive 701 that’s having a few problems. Please advise how I can perform Diagnostic tests.
Also, is there somewhere I can get a list of what the codes mean?
Thanks, Stephen.July 26, 2006 at 8:30 pm #183117Penguin45
ParticipantRe: F&P Smart Drive 701 – Diagnostic tests
Diagnostics (phase 2): Hold “Wash Temp Down” and the “Power”. Wait for two beeps, press “Advance” once. Toggle “Spin” until Hold and Slow Spin leds are lid. Progress board lights will now indicate the last fault. It’s a binary code from right to left, ie 1+2+4+8+16 etc. Lit is a digit, off is a zero.
essandemm wrote:Also, is there somewhere I can get a list of what the codes mean?
Can’t publish the whole list, info is copyright to F+P. Tell us what you get and we’ll sort it from there.
Penguin45.July 27, 2006 at 11:07 am #183118essandemm
Thanks penguin45. I’m pretty sure I followed your instructions. I didn’t get 2 beeps but otherwise it worked. This is the result.
The 5 lights from long wash to short wash were
0 0 1 0 0 and then Rinse 1, Final Rinse 0, Spin 0.I did it 4 times because the first time, I wasn’t sure what I was doing & I wrote down the following: the other 3 times I got what I’ve said above.
0 0 1 0 0 and then Rinse 1, Final Rinse 0, Spin 1.The other 3 times I got what I’ve said first. If you could advise what to do in either case, that would be great. If you don’t feel you can tell me both, just the first one I’ve mentioned will do.
Thanks, Stephen.
July 27, 2006 at 7:26 pm #183119Penguin45
OK, first one is the pump timing out – not draining fast enough. Second one relates to the water level control – the machine is not detecting a rising water level.
First one – check drain hose for nip, kinks trapping. If ok, get the machine as empty as possible and drop the pump motor. It’s a twist fit. Check for blockages, stuff getting trapped round the impellor etc. Power off, please.
Second one – check that the air hose is actually connected to the pressure switch and that it isn’t split, kinked, trapped etc.
Let us know how you go,
Penguin45. -
