Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P smartdrive 051
- This topic has 20 replies, 7 voices, and was last updated 20 years, 9 months ago by
admin.
June 27, 2005 at 6:53 am #10358
KeymasterCan someone email me the diagnostics info for a 051 smartdrive? ian.wells@opus.co.nz
June 27, 2005 at 6:56 am #139625alexa
ParticipantHave emailed you the diagnostics
Post back in the forum with your fault code if necessary
June 30, 2005 at 12:13 pm #139626hughnz
ParticipantRe: F&P smartdrive 051
Hi alexa, would you please also email me one? and does it also suit 015 model? my email is abargaincity@hotmail.com
cheers
hughJune 30, 2005 at 12:33 pm #139627alexa
ParticipantPost back with your fault code
June 30, 2005 at 10:17 pm #139628hughnz
sorry, i still haven’t got your email for diagnostics instructions. please email me on abargaincity@hotmail.com
thanks
hughJune 30, 2005 at 10:57 pm #139629alexa
ParticipantThis is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed.
July 1, 2005 at 12:17 am #139630hughnz
Hi, sorry about that but i received Activation email from site webmaster in this email address, don’t know whats wrong. would you please resend to linsoncomputers@xtra.co.nz ?
cheers,
hughJuly 1, 2005 at 9:26 am #139631hughnz
thank you for diag info. washer is LW015, console lights up but no action after hit START/PAUSE. By following your instruction, the level3 code is 10000100.
also some other lights appear on except the progress lights. what i’ve done on the machine is: i tried to diagnose it by TEMP DOWN and POWER, but didn’t press ADVANCE, then machine wont turn off with 3 lights(rinse,final rinse and spin) flashing all the time. don’t remember what i did then(maybe try to reset by START/PAUSE and POWER), now machine wont turn off with the other 5 lights on(long wash to short wash) all the time.
please help.
cheers,
hughJuly 2, 2005 at 12:11 am #139632alexa
ParticipantYou need to push the advance button to accesss level 3 fault code.
Have emailed you the readout for the fault code you indicated.
If the machine won’t turnoff then possibly moisture or corrosion on switches.
Machines have been known to turn themselves back on and these require a new board.July 2, 2005 at 9:22 am #139633hughnz
Hi Alexa, thank you very much. just wondering if I’ve got real fault code due to the following reasons:
before entering the diagnostic mode, machine was not entirely off since five lights(long wash to short wash) still on. when entered the diagnostic mode,machine did not have 2 short beep and high water level light is on all the time.
can I ask do those affect the accuracy of diagnostics?cheers
hughJuly 3, 2005 at 5:02 am #139634alexa
ParticipantIf your bottom two spin lights didn’t come on (spin hold & slow spin) and your wash lights didn’t extinguish prior to the fault readout your board has had it. If they did extinguish and you did get the readout then the fault code acts as a guide. Ive posted you the possible causes. Could be either board.
July 5, 2005 at 9:17 am #139635Marktc44
ParticipantI have posted this in the wrong thread..
Reposting .. Sorry for the inconvienience
July 5, 2005 at 9:32 am #139636hughnz
Hi alexa, thank you for your help. still playing w my lw015, after POWER on, press START/PAUSE, machine wont start but beeping with fourth washing led flashing, ie 00010000, is it the actual “fault code”? whats that mean? it is different from the one i got by diag mode. cheers.
July 5, 2005 at 10:56 am #139637alexa
ParticipantPower on and only one led, beeping, start pause does nothing?
This is not the fault code.
Turn off at wall for 5 seconds then turn on again.
If not normal new board required.July 6, 2005 at 12:21 pm #139638abre2182
