Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F+P Smartdrive 053 (machine wont fill for the RINSE cycle)
- This topic has 10 replies, 3 voices, and was last updated 20 years, 10 months ago by
admin.
May 22, 2005 at 11:54 pm #9735
KeymasterHi there,
My little machine wont fill for the rinse cycle. It fills fine initially and can be filled with water manually (from a bucket!) but the tub just spins slowly (not filling) when the wash cycle is complete and drained.
Any help would be greatly appreciated.
ThanksGord.
May 22, 2005 at 11:57 pm #135590admin
KeymasterRe: F+P Smartdrive 053 (machine wont fill for the RINSE cycl
Also, I have been into diagnostic mode and there is no light for the lid being open and also no light for the tub being out-of-balance. The water intakes and pump seem to work fine in this mode!!
thanks
GORD again.
May 23, 2005 at 12:46 am #135591alexa
ParticipantPost your email or fax no. and I’ll send you the diagnostics
May 23, 2005 at 12:58 am #135592admin
Sounds great – cheesedoctor@hotmail.com
Thanks for your help,Gord
May 23, 2005 at 1:09 am #135593alexa
ParticipantRe: F+P Smartdrive 053 (machine wont fill for the RINSE cycl
I’ve emailed you the diagnostics
Post back to UKW with the fault code
If I’m not there then penguin 45 will assist when he’s online
Do not email as I’m about to go on away and nobody will respond
Best if you could do this asap
May 23, 2005 at 3:41 am #135594admin
Thanks so much
I’ll have a look tonight
and post the relevant details tomorrow
– no rushThanks,
GordMay 23, 2005 at 10:09 pm #135595admin
The smartdrive is a phase 3 (MW053) compact 5kg+
Going into diagnostic mode does not produce 2 beeps!!
There is no fault code shown at Level 3!
Though:
Level 8 = 20
Level 9 = 37
Level 10 = 8
Level 14 = 42
Level 15 = 55“Lid Open” LED goes on.
“Out of Balance” LED goes on
“Size Switch” goes on – 5.5kg
“Pump” goes on
“Hot water” LED goes on and opens hot water valve
“Cold water” LED goes on but valve doesn’t let water through properly.even when i run a cycle on hot water, the machine wont fill at the rinse stage.
any assistance – greatly appreciated
GORD
May 24, 2005 at 12:23 am #135596Penguin45
Have you checked the cold water solenoid coil Gord? Should give a reading of 3-4k ohms.
Power off first………
Penguin45.May 29, 2005 at 9:31 am #135597alexa
ParticipantPenguin 45 is right that the cold water solenoid is faulty
Their 12 volt supplied coils however should read 15 ohms and are basically bullet proof at these voltages
You should first check that the water runs freely through the hose and that the filter in the valve opening where you attach the inlet hose is free of debris/dirt
The valve itself is however a major source of income for repairers as their diaphram is of poor quality and will therefore split and subsequently won’t let the water through properly.
Also these machines only rinse on cold water so a hot fill selection will not bypass this component.
Likewise the hot and cold valve are different and so cannot adequately be swapped
Drain the machine to avoid reboot errors
Ensure the power and water are off and disconnected at the wall.
Take all precautions not to get water in the electronics else forced air drying for a lengthy period will be required.
June 2, 2005 at 9:25 am #135598admin
I seem to be having a similar problem with my smartdrive 053. When filling the tub it ‘sounds’ wrong and a quick peek under the lid shows just a dribble of water making its way in…
If both of my inlet valves have packed it in, are they easy to replace? (without expensive repair labour bills of course)
June 2, 2005 at 10:35 am #135599alexa
ParticipantYes they are easy to replace but then I,ve done it a 1000 times.
1/. Order the parts
2/. Wait till you have the parts before attempting replacement
3/. Turn power off
4/. Disassemble in an orderley fashion
5/. Reassemble in reverse.
Post here if you have any problems although I am going to the coast for the weekend so will be unavailable till Monday
Anyone should be able to supply or ph F&P 1300 650 590 24hrs for mailout of parts
Probably $100 max for both
Note there is a difference between hot and cold
Should take five to ten minutes Max.
You should allow 1 hr
- The topic ‘F+P Smartdrive 053 (machine wont fill for the RINSE cycle)’ is closed to new replies.
