Re: F&P smartdrive 701 dead
nod130 wrote:Thanks to Penguin 45 ,I’ve found the fuse blown on the motor controller pcb. If I replace the fuse , can I run diagnostics to determine the cause of the problem. Btw. I can read the voltage (250) on the fuse but not the rating. Any clues?Thanks in anticipation , Don.
2A QB fuse seems to be the one.
You need a test meter at the very least to find the fault. Faulty/leaking pumps and wiring to the motor chaffing through are all known causes. One poster had his board destroyed by a faulty water valve. Component failure on the pcb itself can blow the fuse. You’re going to have to get in there and track it down.
Last post moved here to keep it all nice and tidy.
