F&P SmartDrive 708 not filling (00111000)
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P SmartDrive 708 not filling (00111000)
  • #22939
    spiv_wa
    Having trouble with 708 washing machine.
    Machine will fill for about a minute and then stop to a trickle and not fill properly. At one stage the machine was beaping every 5 sec with the hot & cold lights lit up. Inlet hoses are not blocked and water temp seemed ok. Outlet hose also drained ok at the end of cycle.
    Circuit board looks in ok condition (no burn marks) and there are no loose connections anywhere. Lid switch seems to work correctly (i.e. when I open the lid the water stops and starts again when I close it)
    Error code is 00111000
    Any help would be much appreciated.
    Thanks,
    Shaun
    #196588
    bigsmokepiker
    Re: F&P SmartDrive 708 not filling (00111000)
    If you had just described fault without flagging fault code would have said FAULTY Inlet Valve
    Fault Code Given (56) Manual suggests Bowl Check no valid Fault
    Ie While carrying out bowl check the smartdrive has not been able to
    determine bowl status
    Possible Causes
    1/Check that there are no foriegn objects between bowls
    Check pressure tube not blocked or kinked
    2/Motor controller(Main PCB Fault)
    It could be temp sensor failure or pressure switch failure(These are integrated into the motor controller (main PCB)
    Have you tried filling on cold Or hot water only?
    #196589
    spiv_wa
    ok thanks, will try that tonight.
    Where are the bowls located?
    #196590
    bigsmokepiker
    Open the lid & PRESTO
    Take off Agitaor & check under that as Well
    Wing nut down the centre
    #196591
    spiv_wa
    lol the bowl, Sorry I am more used to float bowls i.e. carburetors.
    Anyway, I have tried filling the machine twice. Once on cold and once on hot. Both times slow trickle of only cold water came out. So in diagnostic mode held down hot button then held down cold; hot water flowed freely but cold water only trickled out.
    Error code is 00110010
    So, would you suggest replacing cold water valve? If so can you please suggest where it can be purchased (in Perth Western Australia).
    #196592
    bigsmokepiker
    Part number 426143
    F&P Phone 1300650590
    #196593
    spiv_wa
    Thanks so much for your help. That fixed it.
