F&P Smartdrive 9 Excellence keeps shutting off when fill
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P Smartdrive 9 Excellence keeps shutting off when fill
  • #16994
    eraser
    Hi All,
    I have a 5 year old F&P smartdrive 9 excellence model GW709NZ.
    Whenever I start the machine, water starts entering then is abruptly shut off. This happens a couple of times before the machine starts beeping. I get the same kind of thing when putting it on spin cycle.
    I think I’ve been able to get into diagnostics and they read as follows:
    00101011
    Any help would be greatly appreciated!
    #172465
    Re: F&P Smartdrive 9 Excellence keeps shutting off when
    Fault with OOB switch. These are so and so’s for corrosion problems. Replacement usually solves the problem. It can be the motor control board playing up, but this is very unusual.
    eraser
    Thanks, Il’ll get someone out to have it fixed. I’m in IT so diagnostics are one thing but I wouldn’t know where to look for an OOB switch. Is this an expensive operation?
    #172467
    eraser wrote:Is this an expensive operation?
    Naah, it’s just a microswitch (p/no 425373) or dodgy wiring, so shouldn’t hurt too much 😀
    Cheers,
