F&P Smartdrive 9 Fault
  • #54096
    desertknight
    Hi our machine at home fills for a few seconds then stops. Fills for a few seconds and stops.
    All the lights on control pcb seem normal and will start too fill or if you change to spin start to drain but always after few seconds stops.
    I went into diagnostic. All the lights on the top row are off.
    Does anyone know what fault this indicates.
    Glenn.
    #318373
    Re: F&P Smartdrive 9 Fault
    Normally a water valve problem – probably the cold valve. There is no model 9.
