Re: F&P Smartdrive ecellence gw708u error code 00001011
11. Suggests a problem with the water level control circuit – the computer does not agree with the readings from the level sensor.
Easy things to check – air hose to the level switch is not disconnected, pinched, trapped, kinked or holed. Top deck off for access.
Hard things to check – the level switch itself. This is not an on/off switch, it is a proportional control device, giving a frequency output to be read by the computer. It is an integral part of the motor control pcb, so failure involves replacing the board.
