Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P Smartdrive GW508 – Pump always on & won’t fill w
- This topic has 4 replies, 2 voices, and was last updated 20 years, 2 months ago by
Simon__NZ.
January 12, 2006 at 4:08 am #14741
Simon__NZ
ParticipantHi All.
Hoping someone can please help with this?
GW508 stopped when a particularly heavy load became unbalanced.
Replaced the Fuse which had blown.
Now, when I plug in & switch on mains, the Pump runs continuously, and can’t fill with water (in one end & out the other!!)
Also, the Cold water is now just a trickle, but the Hot is normal.
I can load handwashed clothes, and use the Spin cycle, when the Alarm sounds when at the end. And all the while the Pump is still running.
The Code I get is 00100100.
If someone could please make some suggestions, that would be much appreciated.
Many thanks.
Simon
Auckland – New ZealandJanuary 12, 2006 at 9:03 am #160659Simon__NZ
ParticipantF&P Smartdrive GW508 – Pump always on – Correction
I have a correction to the Code I supplied in my original message.
I had not used the “..advance once & spin speed up…until Hold & Slow etc…”
When I now do that, the lights, from left to right show 00001101
If I have figured your binary codes out correctly, that makes an error code 13?If I read them from right to left, I get 10110000 which makes an error code of 176??
I wonder if it relates to the OOB (Out Of Balance) Switch, as the washer was overloaded & unbalanced when the fault first arose?
Thanks in anticipation.
😕January 12, 2006 at 9:23 am #160660Penguin45
ParticipantRe: F&P Smartdrive GW508 – Pump always on & won’t fi
13 is that the display board has detected the pump running continuously. It’s switched by the motor control board. Be advised that there is a permanent live feed to the pump as long as the machine is plugged in, so be careful when circuit testing.
Penguin45.January 13, 2006 at 5:52 am #160661Simon__NZ
Many thanks for that Penguin.
Is the Motor Control Board something I can replace, and if so, can you please suggest where I could obtain one?
Where do I locate the Motor Control Board please, and what tests do I conduct to see if it needs replacing? Sorry, new at this.
Thanks again.
Cheers
SimonJanuary 13, 2006 at 8:30 pm #160662Penguin45
Hi Simon.
The motor board is the lower one of the two in the fascia panel. To perform continuity testing you will need a multimeter and the know-how to use it. If you are not sure, please get pro help – the computer boards are expensive and a mistake would be unfortunate…….Regards,
Penguin45. -
