Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P SmartDrive GW603 Washing Machine Slow Water Fill
- This topic has 3 replies, 3 voices, and was last updated 20 years, 4 months ago by
Rot0r.
November 22, 2005 at 12:07 pm #13492
Rot0r
ParticipantHi,
I have a Fisher & Paykel SmartDrive GW603 washing machine, when the machine goes to fill the machine with water it is extremely slow, cold water seems to be slower than hot. I took the water hoses off and the hoses aren’t blocked and the filters look clean.
Any suggestions?
Could the problem be related to the water inlet valves? and how can I test to see if they are the problem and are they expensive or difficult to change?
Thanks, any help would be appreciated.
November 22, 2005 at 9:09 pm #155163Penguin45
ParticipantRe: F&P SmartDrive GW603 Washing Machine Slow Water Fill
Hi Rot0r,
There are two types of water valve on your appliance. The hot water valve is a non-proportional type, ie when energised it is fully open and allows water into the machine based on the household pressure. The cold water valve is a proportional type, ie it can adjust the flow of water into the machine. During fill for wash, if the hot flow is slow it is likely that the cold flow will be slow as the machine is trying to achieve the correct wash temperature by mixing the fill.The valves do go faulty – 425320 is the proportional cold valve, 425324 is the hot one. I regret I cannot advise you with prices – I am half a world away.
Penguin45.November 23, 2005 at 8:19 pm #155164Rot0r
Thanks for the information Penguin45, do you know if there is anyway of testing the valves? As the water flow seems faster when the temperature setting is hot but gets slower when the temperature setting is lowered. This doesn’t seem right if the hot water valve is a non-proportional type, could anything else cause the slow water flow?
Thanks again.
November 24, 2005 at 6:27 am #155165KiwiwantsworkinCanada
If the hoses havent been swapped, then the cold valve is faulty. This usually has a hissing/whooshing noise when filling. Easy to replace, just remember to take the seal off the old valve and fit it to the new one before refit it into the mixing chamber.
Happy fixin’ 😉 -
