Re: F&P Smartdrive gw701 – All wash progress lights lit
The five lights coming up mean that the restart facility is disabled. If restart is on, the machine will store any fault in the memory, then try to carry on with the programme.
To set it to “on”, enter diagnostics – Hold down Wash Temp Down, the press Power. After the two beeps, hold down Advance and press Water Level Down. When the Low Water Level led is lit, restart is on. Power off and it should be saved in the eeprom.
The fault code you came up with is a braking problem. Drum should stop within 10 seconds from spin. The controller is the usual culprit, although it is always worth checking wiring to the Rotor Position Sensor and motor for chaffing, breakages, water damage and the like.
HTH,
