F&P Smartdrive MW059 – 00001001 error code
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P Smartdrive MW059 – 00001001 error code
  • #18227
    justdunc
    Hi All
    New motor control module has been installed after the machine died mid load.
    Have been able to empty the water in diagnotics mode.
    Get 00001001 when I try normal operation
    Any ideas on the cause?
    #178219
    justdunc
    Re: F&P Smartdrive MW059 – 00001001 error code
    Problem solved after searching and searching through this forum
    Thanks to penguin45 who posted the solution in another post
    Here’s the solution:
    Penguin45 wrote:You’re halfway there – now you’ve got the size error. So – Press and hold “Water temperaure up”, then press “Power”. You should now have up to three LEDs lit – “cold water”, “low water” and “hold”. For a 5kg machine, press “wash temp up”, then “power”. For a 6kg machine, press “water level up”, then “power”. For 7kg, press “spin speed up”, then “power”.
    To see if you’ve got it right, start a programme……..
    I did press “wash temp up”, then “power” for my 5kg machine
