F&P Smartdrive MW059 – 00111110 error code
Home Forums Public Support Forums International Forums Australasian Appliance Forum F&P Smartdrive MW059 – 00111110 error code
  • #18384
    justdunc
    Hello
    A new error code I havent’t seen before
    00111110 with beeping
    Happened as it was emptying after the wash cycle. The drain pump runs in spurts and empties water likewise
    Managed to empty it out after about 30 odd rounds of beeping. Drain pump worked constantly at the end of empty without a problem
    Any idea on what this error code means?
    justdunc
    #178817
    Re: F&P Smartdrive MW059 – 00111110 error code
    Drain pump is cooking itself – machine has detected excessive current to the pump motor. Time for a new one…………. 426956P is what you want.
    justdunc
    Thanks for that.
    It’s blown up – switched it on this morning – motherboard blown again.
    Damn…going to buy a new washing machine!
    #178819
    Biggus
    I’m having the same problems too but I put a new pump in about 4 weeks ago and a new mainboard in about 12 months ago.
    the pump starts..stops..starts..stops..starts..stops and then just beeps continually.
    Any suggestions?
    Cheers
    bigsmokepiker
    Whats the Model # & Any Fault Codes?
    See Sticky
    #178821
    Biggus
    Oops, sorry, its the MW059 and the fault code 00111110 error code , whell that’s what flashes up while its beeping, if I press start the red spin button flashes quickly, almost like it has a loose connection
    #178822
    New pump or not, it’s drawing too much current……… Possibly partially blocked and dragging the impellor, may be getting wet?
    bigsmokepiker
    Fault Code 62
    Indicates Excessive Pump Curren
    Usually faulty pump (Pump Trips out When it overheats)
    In Some instances Thou it may be Motor Controller
