F&P Washer GW500B-U
  • #19698
    senator
    Hi, Have a problem with F&P GW500B-U, error code 10100100 (read right to left) with the hold & slow lights lit. Can anyone shed some light on this code and what is required to repair it. Thanks…
    #184166
    Re: F&P Washer GW500B-U
    Don’t see that one very often…… The computer has applied the brakes for 20 seconds and detected that the drum hasn’t stopped. Generally it’s a wiring/continuity problem, so multimeter time. Also check the area where the wiring is attached to the drum and running into the stator for chaffing and broken wires.
    Power off, please.
