Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Framtid dov8/2
- This topic has 5 replies, 2 voices, and was last updated 15 years, 6 months ago by
abrielle.
October 26, 2010 at 8:29 am #58303
abrielle
ParticipantI recently bought this oven from Ikea.
I have the instruction manual but it is not clear how to set a delayed start and finish in order to switch on the oven later in the day.
I have tried to follow the instructions but the oven comes on immediately!
Can anyone help please?
October 26, 2010 at 10:13 am #334026don
ModeratorRe: Framtid dov8/2
Can you post up the information on the label probably behind the door please. It could be either a PNC number or there could be two barcodes, I’m guessing it’s either Electrolux or Whirlpool made.
Don
October 26, 2010 at 11:00 am #334027abrielle
ParticipantRe: Framtid dov8/2
TYPE: 92D3D30KD
PNC: 944171528These are the instructions (Symbol/Function/Description):
|->| Cooking duration – To set how long the oven is to be in use
->| End of cooking – To set when the oven is to switch off
|-> |->| Cooking duration and End of cooking combined – To set delayed start of the appliance
I am trying to work out how to set the top oven to come on at 19:00 hours and switch off at 18:30 hours.
When I set the temperature to 200C, the oven comes on immediately so I am obviously not understanding the instructions!
October 26, 2010 at 11:02 am #334028abrielle
Sorry for typo – that should be 17:00 start!
October 26, 2010 at 11:34 am #334029don
abrielle wrote:I am trying to work out how to set the top oven to come on at 19:00 hours and switch off at 18:30 hours.
The programmable timers only usually work with the bottom oven 😉Looking at the instructions online it appears you only need enter the cooking time ie 90 minutes in your example and set the end time to 1830 and that should be job done.
HTH 🙂
Don
October 26, 2010 at 1:38 pm #334030abrielle
The instructions do not mention the fact that this only works on the larger, main oven. I will try it later.
Sad if this is the case as it would be nice to have a couple of jacket potatoes ready when we get home in the evening! Using the main oven would be a bit wasteful for this.
Thanks.
