Freezemaster Fridge/Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Freezemaster Fridge/Freezer
  • #23131
    mikel
    The drain from the fridge is constanly blocking it turns out it is freezing up and it takes a while to unfreeze with hot water the drain tube is housed within the cabinet I was thinking of rerouting it outside but it doesnt look if the back of the cabinet comes of easy ?wonder if anyone has resolved this ive turned the fridge temp as low as i can
    mike
    #197102
    Hi Mike,
    Sounds as if you may have a dodgy thermostat or sensor causing the fridge to overfreeze.
