The drain from the fridge is blocked it runs to a tray at the baseof the f/f and is not accesible it appears by using a wire from top and bottom that there is a bend and i cant get a wire right thro the tube would it be possible to use a drain blocking fluid or is it possible to get access to the tube
thankyou mike
