Freezer cold Fridge not
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Freezer cold Fridge not
  • #17316
    giley
    I have a Zannussi ‘Freezone’ F/F
    Model: ZK 61/27R Type: B256010 Coolant: R134a
    Freezer works but fridge doesn’t cool at all, though light is fine. It seems this general problem is not uncommon, and not sure if it is fixable
    #173765
    Dave_Conway
    Re: Freezer cold Fridge not
    It’s possible the thermostat has failed but you’d normally expect everything to defrost as it controls the single compressor which cools both compartments.
    Is the motor (compressor) running constantly or does it cut in and out ?
    #173766
    giley
    Hi – thanks Dave.
    The motor seems to be running smoothly, freezer still freezing.
    Giles
    #173767
    Dave_Conway
    Dave_Conway wrote:Is the motor (compressor) running constantly or does it cut in and out ?
    You didn’t answer this bit 😀
    #173768
    giley
    Sorry – motor seems to be running smoothly
    #173769
    giley
    Sorry Dave, meant to say that the motor is constantly running – disctracted by my children.
    giles
    #173770
    Dave_Conway
    If it’s running constantly then a system failure is the likely cause I’m afraid, as long as it’s not the fan motor in the freezer you can hear.
    An engineer calling is the only sure way of telling 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of course. Check the repairs@ link below 🙂
